Irule required for mentioned url
Hello,
Need an Irule for mentioned url -
When we call urls starting with http://uat-alfresco-euro.kamlesh.com:2095/alfresco/webdav it should call http://uat3.alfresco-euro.kamlesh.com:2095/alfresco/webdav
For example, if I try to reach in my browser http://uat-alfresco-euro.kamlesh.com:2095/alfresco/webdav/test/123 VIP should call http://uat3.alfresco-euro.kamlesh.com:2095/alfresco/webdav/test/123
Original URL should be kept and not be replaced
Note- In url there is - uat and uat3(after redirection) and
Original URL should be kept and not be replaced.
Kindly help for redirection of url Thanks in advance
Regards Kamlesh Y
You can try an irule simmilar to below code :
    if { [HTTP::host] contains "uat-alfresco-euro.kamlesh.com" } {
        HTTP::redirect http://[string map { "uat-alfresco-euro.kamlesh.com" "uat3.alfresco-euro.kamlesh.com" } [HTTP::host]][HTTP::uri]
This is a simple redirect. Just saw that you need to rewrite the host header so Stefan’s irule is correct. But you may need to rewrite the response body to make sure that uat3.alfresco-euro.kamlesh.com is not visible from external.
Hi Kamlesh,
if you want that the original URL in your browsers address bar shouldn’t be changed, then we are talking about URI rewriting instead of HTTP redirect. So in your example you want to exchange the host-part of your URL/request. Please try this one:
     Replace host header with the internal name
    HTTP::header replace Host uat3.alfresco-euro.kamlesh.com:2095
Please also have a look on the ProxyPass Lite iRule in case you might need to rewrite something in responses from the server as well. Hope that helps.
Ciao Stefan :slightly_smiling_face:
If you are trying to mask the domain name, try this:
HTTP::host [string map {"uat-alfresco-euro.kamlesh.com" "uat3.alfresco-euro.kamlesh.com"} [HTTP::host]]
when HTTP_RESPONSE {
if { [HTTP::header values Location] contains "uat3-alfresco-euro.kamlesh.com" } {
HTTP::header replace Location [string map {"uat3-alfresco-euro.kamlesh.com" "uat.alfresco-euro.kamlesh.com" [HTTP::header value Location]]
