I need replace a set if URI from my URL with single one.
e.g
I have these URLs which are being used now
what i want is that when ever there is a set of uri i.e “/app/cs/” in URL that should be switch to “/cas”
and new urls should be
e.g
log local0. "Incoming URI = [HTTP::uri]"
if { [string tolower [HTTP::uri]] starts_with "/app/cs" } {
set uri [string map -nocase {"/app/cs" "/cas"} [HTTP::uri]]
log local0. "New URI = $uri"
HTTP::uri $uri
** disable the logging statements once you’ve verified correct operation.
Also note that this transparently changes the request URI on ingress traffic (the client browser does not see the change). If you need to change “/app/cs” instances in outgoing payload (headers, redirects, object references), then a STREAM profile iRule is in order.
I wrote the next irule:
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "/swscersalud" {
pool Pool_Consorcio_test set VARIABLE[string map -nocase {“/swscersalud/wscersalud.asmx” “/Services/Utility/certificacionSalud/WS/Implementation/Service.serviceagent/WSCERSALUDSoapEndpoint”} [HTTP::uri]] HTTP::uri $VARIABLE log local0. “Ingreso al swscersalud [HTTP::uri]” } "/wsconadmo" { log local0. “Ingreso al wsconadmo [HTTP::uri]” set VARIABLE[string map -nocase {“/Wsconadmo/OyS.asmx” “/Services/Utility/OyS/WS/Implementation/WSCONADMO.serviceagent/OySSoapEndpoint”} [HTTP::uri]] HTTP::uri $VARIABLE pool Pool_Consorcio_test_V2 } } }
when HTTP_REQUEST_SEND { switch [LB::server addr] { “10.237.146.1” { HTTP::header replace Host “vmpesbserver:14002” } “10.237.146.2” { HTTP::header replace Host “vmpesbserver2:14002” } }
Is this right?
