Hello all,
Can I do this in only one irule?
Uri to Uri, and Uri to Url
Thanx and regards
Prefix: /Institucional/comercial/Acuerdos/entrada_acuerdo.asp
To URL prefix: /onlineCetelem/FcControlador.srvl?COMANDO=ENTRADA_ACUERDO&URL_LOGICA=ACUERDOS&
Prefix: /Agencia_Online/Transaccional/Login_AgenciaOnline.asp
To URL prefix: http://www.cetelem.es/Agencia\_Online/Transaccional/Login\_AgenciaOnline.asp
Hi jato,
you can do it with redirect (by client) or replacing the http uri in the request event by bigip.
The example:
if { [HTTP::uri] starts_with "/Institucional/comercial/Acuerdos/entrada_acuerdo.asp" } {
HTTP::uri /onlineCetelem/FcControlador.srvl?COMANDO=ENTRADA_ACUERDO&URL_LOGICA=ACUERDOS&
} elseif { [HTTP::uri] starts_with "/Agencia_Online/Transaccional/Login_AgenciaOnline.asp" } {
HTTP::redirect " http://www.cetelem.es/Agencia_Onlin...Online.asp"
I hope this helps.
Cheers
Marek
Other question.
Can I catenate several if’s?
hoolio
4
A switch statement would probably be easier to set up and manage. Here is a basic example you could use to get started with.
switch -glob [string tolower [HTTP::uri]] {
"/Institucional/comercial/Acuerdos/entrada_acuerdo.asp*" {
HTTP::uri "/onlineCetelem/FcControlador.srvl?COMANDO=ENTRADA_ACUERDO&URL_LOGICA=ACUERDOS&;"
"/Institucional/comercial/Acuerdos/Entrada_acuerdo.asp*" }
"/zonacliente*" {
HTTP::uri "/zonaClienteCetelem/;"
default {
Take some default action?
Aaron
