iRule redirects causing pool member issues
Hi everyone, I have an iRule that works accordingly to what it was intended to do. The problem is that when the VIP which contains this irule shows the VIP (Green) up when the pool members are actually brought down. I have verified that this irule is causing this weird issue. I had removed the irule and the VIP did go down accordingly. If the irule is applied, the VIP stays up. Does anyone know why this irule is causing this? Here is my setup:
VIP information: Default Pool: Windows_pool
iRule:
Code
    if { not ([HTTP::host] starts_with "www.") } {
            HTTP::redirect https://www.[getfield [HTTP::host] ":" 1][HTTP::uri]
    elseif {[HTTP::uri] starts_with "/ChaptOne/Page1/Blue/" and [HTTP::uri] contains "/HAPPY" and not ([HTTP::uri] contains         "/ABC" or [HTTP::uri] contains "/CDE")} {
    HTTP::respond 301 location "https://www.mainpage.com/chapter4"
switch -glob [HTTP::uri] {
    "/Sunday*" -
    "/Monday*" -
    "/Tuesday*" -
    "/Wednesday" -
    "/Thursday*" {
    pool Unix_pool
    default {
    pool Windows_pool
Code
Presumably because the rule contains the HTTP::redirect and ::respond commands and thus the VS can still ‘handle’ traffic? I’m only guessing and had no idea things were quite so sophisticated. Perhaps try commenting those bits out and see if things change?
I believe this is a known condition because you’re assigning pools within the iRule. If you just need the VIP to show red, perhaps to trigger a GTM monitor, then you’d probably need to use an iCall or user_alert.conf script to manage VIP viability.
If, however, you just need to make sure you’re not load balancing to downed pools, something like the following may help (a minor modification of your iRule):
    if { not ( [HTTP::host] starts_with "www.") } {
    } elseif { ( [HTTP::uri] starts_with "/ChaptOne/Page1/Blue/" ) and ( [HTTP::uri] contains "/HAPPY" ) and not ( ( [HTTP::uri] contains "/ABC" ) or ( [HTTP::uri] contains "/CDE" ) ) } {
            "/MyRx*" -
            "/Monday*" -
            "/Tuesday*" -
            "/Wednesday" -
            "/Thursday*" {
                if { [active_members Unix_pool] < 1 } {
                     ...do something here... (splash maintenance page?)
                    pool Unix_pool
            default {
                if { [active_members Windows_pool] < 1 } {
                     ...do something here... (Splash maintenance page?)
                    pool Windows_pool
Please take a look at this post:
iCall is for 11.4. I’m only on 11.2. Is there any other way around this besides having to upgrade?
If you look at step 3 in the link, that’s the basis of using a raw user_alert.conf config. Just execute your TMSH call in that exec command= section.
Do you think if we remove the pools in the iRule and replace them with a URL, will this issue be mitigated?
Do you mean URI’s (different paths on the same web server), or URLs (as in a 30x redirect)?
