Irule-redirection
Dear Expert,
I have requirement for redirect url. for example i have url www.xyz.com it has to redirect to abc.com then it will open one form page once the user completed this page it has to redirect to again www.xyz.com
can you please help me out to acheive this one
You can redirect fine between both domains, but I don’t know about the form part.
Technically, if you manage both www.xyz.com and abc.com you could send the form html using an iRule but from the way you asked your question I’m not so sure what you even want. :slightly_smiling_face:
Do you wish F5 to issue this form, or is this hosted externally? Does F5 require to validate information issued in the form in any way?
Functionalities that come with APM license can help you set this up pretty easily.
