irule redirection question
i guess i am looking for an opinion on an idea i have.
we manage a handful of domains and are starting to get more and more redirect requests. i was told by our ecom director that i should expect more and more to come in. my concern is the way we have done them in the past is to setup a dns entry, point it to an ip, nat to a vip and then do a redirect with an irule.
i had thought that maybe i should consider doing the same but using one ip, and then just add to my irule and do a redirect based on the inbound uri request. i guess i am wondering that if this were to grow to 10,20, or even 30 different redirects would this become problematic?
thanks for any opinions or ideas on this.
scott
Hi Scott,
What you’ve described is entirely possible. We have customers who are using datagroups with 100’s and 1000’s of source/target/action (rewrite, redirect, etc).
Aaron
Thanks Aaron,
Out of curiosity is it just and if…then setup? or something more complex. I do realize from previous redirects you must convert all to lower first.
Here is an example I wrote for a customer for 9.4.7, based on preliminary project plans. The iRule was never used in production, so I didn’t fully test or performance tune it. I’ve anonymized the rule, but not tested it, so try this on a test unit or test VS first.
If you’re on 10.x you would want to replace the class references with class commands and the global variables in RULE_INIT to static::variables.
 HTTPS Redirects and Rewrites iRule
 BIG-IP ASM
   Tested on version 9.4.7
 Current version:
    v1.2 2009 Sept 10 - Aaron Hooley
 Version: 1.0 - 2009 Aug 14 - Initial version tested
 Version: 1.1 - 2009 Aug 27 - Updates to query string logic
 Version: 1.2 - 2009 Sept 10 - Logging updates
 Description:
    This rule performs HTTP redirection or host/URI rewriting based on the configuration in a datagroup.
 Functionality:
   1. This iRule can be used on an HTTP and/or HTTPS virtual server.
      A single configuration datagroup is referenced regardless of the client side HTTP or HTTPS setup.
   2. The requested host and URI are checked against the source field of the configuration datagroup.
      The longest matching configuration line is used.
      The check is done explicitly using the requested path (/path/to/file.ext in the example URI /path/to/file.ext?param=value),
      logically stripping the query string from the requested URI.
   3. Query string handling:
      The requested query string is not evaluated in the matching, but is preserved in rewrites and redirects.
      If the original request has a query string, it will be preserved.  If the original request has no query string and the destination does,
      the destination query string is used.
 Configuration requirements:
    1. A datagroup named customer_redirects_rewrites_class must be configured using the following space delimited format:
       source (host and/or URI)   | destination (URL for redirects or host and/or URI for rewrites | action (rewrite or redirect)
       www.example.co.uk/dir/     | https://www.example.co.uk/new/directory/                       | redirect
       www.example.co.uk/rewrite  | www.example.co.uk/cs/rewritten                                 | rewrite
       The Host portion of any entry must be set to lower case.
       The fields must use URL encoding for spaces or the parsing will fail.
       The destination must not include the protocol if the action is 'rewrite'
    2. The virtual server must have this iRule added as a resource.
when RULE_INIT {
    Log debug messages to /var/log/ltm? (0=none, 1=minimal, 2=verbose)
   set ::customer_HTTPS_debug 1
   if {$::customer_HTTPS_debug > 0}{log local0. "Debug set to $::customer_HTTPS_debug"}
      set log_prefix "[IP::client_addr]:[TCP::client_port] ([TCP::local_port])"
      log local0. "$log_prefix: -------------------------------------------------------------------------"
      log local0. "$log_prefix: New request to [HTTP::host][HTTP::uri] with UA: [HTTP::header User-Agent]"
    Check requested host/URI against the datagroup to see if there are any matching rules
       for redirecting or rewriting the request.
    Look for the most specific (longest) match by searching first for the requested host/URI and then just requested URI.
    Evaluate all rules to find the longest match.
    Reset the longest match
   set longest_match 0
   set matching_line ""
    Loop through each datagroup line (need to update [set classname] to [class get classname] for 10.x)
   foreach line [set ::customer_HTTPS_redirects_rewrites_class] {
      if {$::customer_HTTPS_debug > 1}{log local0. "$log_prefix: Checking [string tolower [HTTP::host]][HTTP::path] against [getfield $line " " 1]"}
       Check if the current line matches the host/URI
      if {[string match [string tolower [HTTP::host]][HTTP::path] [getfield $line " " 1]]}{
         if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Matched: $line"}
          Found a match, so save the length of the current source token
         set current_length [string length [getfield $line " " 1]]
         if {$current_length > $longest_match}{
             This is the longest match so far
            set matching_line $line
             Update the length of the current match
            set longest_match $current_length
            if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: New longest match: $matching_line"}
    Check if we haven't found a host/URI match.
   if {$matching_line eq ""}{
         if {$::customer_HTTPS_debug > 1}{log local0. "$log_prefix: Checking [HTTP::path] against [getfield $matching_line " " 1]"}
         if {[string match [getfield $matching_line " " 1] [HTTP::path]]}{
            if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Matched: $matching_line"}
            set current_length [string length [getfield $matching_line " " 1]]
               if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: New longest match: $line"}
      if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: No match for [HTTP::host][HTTP::uri], exiting."}
       If there still isn't a match then exit this event in this rule
      return
       There was a matching line in the config datagroup so save the line
      set destination [getfield $matching_line " " 2]
      if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Processing matching line: $matching_line"}
       Check for a query string in the original request as we'll need to include it in the redirect
       As there is a bug with HTTP::query (CR96326) parse HTTP::uri to get the query string
      set request_query_string [getfield [HTTP::uri] ? 2]
       Check if the source and destination both have a query string
      if {$request_query_string != "" && [scan $destination {%[^?]?%[^?]} destination_path destination_query_string]==2}{
         set destination [string map -nocase "$destination_query_string $request_query_string" $destination]
         if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Replaced destination query string with original query string.\
            Orig: $destination_query_string Dest: $request_query_string"}
       Check the action from the rule
      switch [string tolower [getfield $matching_line " " 3]] {
         "redirect" {
             Redirect to the new location
            HTTP::respond 301 noserver Location [getfield $matching_line " " 2]
            if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Redirecting to [getfield $matching_line " " 2]"}
         "rewrite" {
             Rewrite the host and URI
               Need to determine if destination is a host plus URI or an absolute URI
               The first character for a URI is a /, and a host plus URI is an alphanumeric
            switch [string range $destination 0 0] {
                   Destination is a URI so just rewrite the URI
                  HTTP::uri $destination
                  if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Rewriting URI to $destination"}
               default {
                   Destination is a host and URI
                   Save the host and URI separately using scan to save everything up to the first / as the host
                     and everything including and after as the URI
                  scan $destination {%[^/]%s} host uri
                  if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Parsed host: $host, URI: $uri"}
  HTTP::header replace Host $host
                  if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Rewrote host to $host"}
                   Rewrite the URI if the destination URI is not empty or /
                  if {[string length $uri] > 1}{
                     HTTP::uri $uri
                     if {$::customer_HTTPS_debug > 0}{log local0. "$log_prefix: Rewrote URI to $uri"}
when HTTP_REQUEST priority 501 {
    This event is for debugging only and can be commented out or removed after testing is complete
   if {$::customer_HTTPS_debug > 0 && [getfield $matching_line " " 3] ne "redirect"}{
      log local0. "$log_prefix: 501: Host: [HTTP::host], URI: [HTTP::uri]"
Aaron
wow, that looks pretty in depth. i will take this and work on converting it to 10.1 and implementing in a qa. in the interim since i only have three now, would this suffice?
if {[string tolower [HTTP::host]] equals “www.example1.com” } {
HTTP::redirect “Chanel Outlet | Replica Chanel Outlet Sale | Home”
elseif {[string tolower [HTTP::host]] equals “www.example2.com” } {
HTTP::redirect “http://redirect2.com/main.aspx”
elseif {[string tolower [HTTP::host]] equals “www.example3.com” } {
HTTP::redirect “http://redirect3.com/lite/main.aspx”
You could do it that way. The [HTTP::host] vaule of a URL isn’t case sensitive only the [HTTP::uri] or [HTTP::path] is and that depends on the Operating System hosting the website.
I this way is alittle cleaner and easier to read:
switch -glob [HTTP::host] {
"www.website1.com" { HTTP::respond 301 Location "http://www.google.com" }
"www.website2.com" { HTTP::redirect "http://www.yahoo.com" }
"www.website3.com" { pool website3pool }
HTTP::respond allows you to specify the HTTP Status Code to a 301 (Permanent)
HTTP::redirect gives a default 302 (Temporary) Redirect
or you can route the traffic to a specific pool.
Hope this helps.
Thanks Michael,
I will look at that. I do have a concern over the case sensitive issue. Originally I had created this iRule with just one redirect (added on for this) and we were having issues. The best I could tell it was as it should be based on examples
here on devcentral. Finally I was forced to open a ticket due to the urgency and the tech informed me to try the case change. It worked immediately.
if {[string tolower [HTTP::host]] equals “xxxx.com” } {
HTTP::redirect “http://www.xxxx.com”
I’m sorry. I’m crossing my realities.
For normal browsing (without the LTM or any iRules) then the case does not matter for what the LTM picks up as [HTTP::host].
When you are processing the [HTTP::host] value through an iRule then the case IS sensitive and needs to be put in a known comparative state, so you should use the “string tolower”. I apologize for the mistake and confusion.
    switch -glob [string tolower [HTTP::host]] {
