irule redirect with wildcards possible?
Hi All
Is there a possibility to configure a Irule for a redirect which contains wildcard?
As example:
https://onlineofferte-test.test.com/(*)
needs to be redirected to
https://onlineofferte.test.com/(*)
So the part where the (*) is should be kept in the url. A complete URL looks like this:
https:// onlineofferte-test.test.com/WebOfferte/Default.aspx?CollCD=UBS8232001
and should be redirected to
https://onlineofferte.test.com/WebOfferte/Default.aspx?CollCD=UBS8232001
Thanks for your help!
you may check HTTP::uri command.
HTTP::uri
something like that maybe
    if { [HTTP::host] equals "onlineofferte-test.test.com" } {
        HTTP::redirect "https://onlineofferte.test.com/[HTTP::uri]"
