Irule Redirect Issue
I am trying to redirect the host portion to another URL
http://2007pece.mpiweb.org redirected to
http://www.mpiweb.org/cms/mpiweb/pece2007/pecetemplate.aspx?id=7390
and http://20007cmme.mpiweb.org redirected to http://www.mpiweb.org/cms/mpiweb/cmme2007/cmmetemplate.aspx?id=7432
and the following iRule is applied but does not perform the redirection
set host [string tolower [HTTP::host]]
if {[HTTP::host] contains “2007pece”} {
HTTP::redirect “http://www.mpiweb.org/cms/mpiweb/pece2007/pecetemplate.aspx?id=7390”
} elseif {[HTTP::host] contains “2007cmme”} {
HTTP::redirect “http://www.mpiweb.org/cms/mpiweb/cmme2007/cmmetemplate.aspx?id=7432”
Please could someone let me know what is wrong with the syntax.
I would really appreciate it.
Thank you very very much.
-Poo
I have also tried the following with no positive results.
if {$host contains “2007pece”} {
} elseif {$host contains “2007cmme”} {
The most obvious question first: have you applied this iRule as a resource to the virtual server you are passing traffic through?
If you have, then next I would throw some logging in there to determine what the issue is. The code looks good to me.
  log local0. "URI: '[HTTP::uri]'"
  log local0. "Host: '[HTTP::host]', lc -- '$host'"
  if {$host contains "2007pece"} {
    log local0. "$host contains '2006pece'"
    HTTP::redirect "http://www.mpiweb.org/cms/mpiweb/pece2007/pecetemplate.aspx?id=7390"
  } elseif {$host contains "2007cmme"} {
    log local0. "$host contains '2007cmme'"
    HTTP::redirect "http://www.mpiweb.org/cms/mpiweb/cmme2007/cmmetemplate.aspx?id=7432"
    log local0. "$host didn't match any filtering criteria"
Run a request through the Virtual with this iRule associated to it and take a look at the /var/log/ltm file. If you still can’t figure out what’s going on, pass the log output back here and I’ll take a look.
-Joe
Thank you very very much for your help.
It works, there were some DNS issues, and another rule that was superceding my rule.
