ok, I am back, strange problem.
Test request I am sending:
[root@bigip1:Active] config telnet 10.10.50.203 80 Trying 10.10.50.203…
Connected to 10.10.50.203.
Escape character is ‘^]’.
GET /vMoD/vMoDGenres?title=R and B HTTP/1.0 ^]
telnet> q
Connection closed.
Seeing in the ltm log:
Mar 24 15:13:31 tmm tmm[824]: Rule vmod_search : URI was matched. Result: /vMoD/vMoDGenres?title=R and B Mar 24 15:13:31 tmm tmm[824]: Rule vmod_search : It worked! /vMoD/vMoDGenres?title=R%20and%20B
But the tcpdump shows:
15:13:31.821046 10.10.50.202.38458 > 10.10.50.236.http: P [tcp sum ok] 1:58(57) ack 1 win 4380 (DF) (ttl 255, id 50573, len 109)
0x0000 4500 006d c58d 4000 ff06 3c33 0a0a 32ca E..m..@…<3..2.
0x0010 0a0a 32ec 963a 0050 8280 d372 c314 39d8 ..2..:.P…r..9.
0x0020 8018 111c 811f 0000 0101 080a 4e3a 2f0e …N:/.
0x0030 5e35 f30e 4745 5420 2f76 4d6f 442f 764d ^5..GET./vMoD/vM
0x0040 6f44 4765 6e72 6573 3f74 6974 6c65 3d52 oDGenres?title=R
0x0050 2532 3061 6e64 2532 3042 2061 6e64 2042 %20and%20B.and.B
0x0060 2048 5454 502f 312e 300d 0a0d 0a .HTTP/1.0…
You can see that BIG-IP is putting “and B” and the end of the URI.
I just can’t figure out where it is padding that. I changed the logging and it shows the same if I comment out the “encoding” section. I am wondering if it is being padded after the rule is executed.
any help would be appreciated.
