Hello all…
We are currently using ISAPI re-write in our portal to re-write uri’s to the appropriate location. With the help of this forum I came up with the following, which works fine for /Portal/Category/
if { [HTTP::uri] starts_with “/Portal/Category/” } {
HTTP::uri "/g2p/KII.G2P.Portal.Web.Pages/Category.aspx?id=[substr [HTTP::uri] 17 “\/”] "
But my issue is that I have a hundreds of entries in my ISAPI file and not all of them are /portal/category/ some do have the /portal/“somthing differnet”, some have a different somthing/something. Obviously I don’t want to create hundreds of iRules or an iRule that has hundreds of “if then else” statements. Does anyone have any other suggestion or thoughts.
Below is a small example of some of the rewrites in my ISAPI file:
RewriteCond Host: test.mysite.com
RewriteRule /Portal/Search\.aspx(.*) /g2p/file.G2P.Portal.Web.Pages.Google/Search.aspx$1 [I]
RewriteRule /Portal/SearchProxy\.aspx(.*) /g2p/file.G2P.Portal.Web.Pages.Google/SearchProxy.aspx$1 [I]
RewriteRule /Portal/etc/(.*) /g2p/file.G2P.Portal.Web.Pages.Google/etc/$1 [I]
RewriteRule /Portal/ExternalLink\.aspx(.*) /g2p/KII.G2P.Portal.Web.Pages/ExternalLink.aspx$1 [I]
RewriteCond Host: www\.test\.mayor\.state\.com
RewriteHeader Host: .* mayor\.state\.com
RewriteCond Host: test\.mayor\.state\.com
RewriteCond Host: cms\.test\.state\.mayor\.com
RewriteCond Host: test\.agency\.state\.com
RewriteHeader Host: .* agency\.state\.com
RewriteCond Host: www\.test\.agency\.state\.com
RewriteCond Host: test\.cms\.agency\.state\.com
RewriteCond Host: test\.another_agency\.state\.com
RewriteHeader Host: .* commerce\.state\.com
RewriteCond Host: www\.test\.another_agency \.state\.com
RewriteHeader Host: .* another_agency\.state\.com
RewriteCond Host: cms\.test\.another_agency \.state\.com
Thanks in advance…
Bob
