irule question - restricted url wild card
I want to be able to create an irule that allows only certain ip addresses to a url, and every other ip gets re-directed to the home page. I have a rule that works the way I want it to, however, the applications team is having the users input a string after the path.
So instead of the user just going to “/web/verificationService” they are actually going to "/web/verificationService?enrollmentId=123&individualId=1372823&lastName=Diaz for example. Each string after the /web/verificationService is unique, so I was thinking of a wild card.
What I tried was set restricted_url “/yesnm/verificationService*”, but I don;t think F5 recognizes the * as a wildcard, as when I test, the re-direction to the home page no longer occurs for IPs not in the irule.
Is there a way to tweak my full irule below without having to get rid of the entire rule and re-write from the beginning? Thanks
Base URL for filter
set restricted_url “/web/verificationService” set redirected_url “/web”
Get the source IP.
set source_IP [IP::remote_addr]
If the request includes the restricted_url…
if { ([HTTP::uri] contains “$restricted_url”) } { Compare the the source IP against a list of internal IP addresses. if {[IP::addr $source_IP equals 10.57.32.0/255.255.255.0 ] or [IP::addr $source_IP equals 10.62.62.18/255.255.255.255 ] or [IP::addr $source_IP equals 10.57.30.0/255.255.255.0 ]} { The source IP is internal. Allow the request. log local0. “Access to $restricted_url allowed. Source IP: $source_IP” } else { The source IP is not internal. Redirect the request. log local0. “Access to $restricted_url redirected. Source IP: $source_IP” HTTP::redirect “https://[getfield [HTTP::host] “:” 1]$redirected_url” } } }
I have used the text string
as wildcard in stream expressions, and I think that is simply TCL syntax, so you might give .*? a try
Hi Chris,
  • the “contains” operator is acutally a “/web/verificationService” wildcard.
  • the “starts_with” operator is acutally a “/web/verificationService*” wildcard.
  • the “ends_with” operator is acutally a “*/web/verificationService” wildcard.
  • the “equals” operator doesn’t include any wildcards.
So you may want to change your code to use the “starts_with” operator to optimize accuracy and also performance.
    Base URL for filter
    set restricted_url "/web/verificationService"
    set redirected_url "/web"
    Get the source IP.
    If the request includes the restricted_url...
    if { ([HTTP::uri] starts_with "$restricted_url") } {
        if { [IP::addr $source_IP equals 10.57.32.0/255.255.255.0] or
             [IP::addr $source_IP equals 10.62.62.18/255.255.255.255] or
             [IP::addr $source_IP equals 10.57.30.0/255.255.255.0] } {
            log local0. "Access to $restricted_url allowed.  Source IP: $source_IP"
            log local0. "Access to $restricted_url redirected.  Source IP: $source_IP"
            HTTP::redirect "https://[getfield [HTTP::host] ":" 1]$redirected_url"
Cheers, Kai
