I am attempting to configure persistence based upon the content of the data stream.
When I use unencrypted source traffic, the iRule works as expected. The iRule was configured as follows:
when CLIENT_ACCEPTED {
TCP::collect 1
when CLIENT_DATA {
log local0. “DATA= [TCP::payload length] -End”
if {[TCP::payload] contains “&u=”} {
log local0. “RD- [TCP::payload] -End”
persist uie [findstr [TCP::payload] “&con=” 5 “&”]
pool stg.us1-rd.service.gehealthcare.com.443
elseif {[TCP::payload length] > 1000} {
reject
else {
log local0. “Collect more”
TCP::collect 1
return
When I switched the configuration to use Client side SSL, I modified the rule to:
when RULE_INIT {
set $nCollect_Passes 1
when CLIENTSSL_HANDSHAKE {
log local0. “CLIENTSSL_HANDSHAKE”
TCP::collect 1
log local0. “Collect”
TCP::collect 1
when CLIENT_DATA {
log local0. “CLNT DATA= [TCP::payload length] -End”
reject
elseif {$nCollect_Passes > 10} {
reject
else {
log local0. “CLNT Collect more”
incr $nCollect_Passes
TCP::collect 1
return
This does not work because the data is encrypted. I get the log message:
Rule : PAYLOAD= ??W??? I???[??v)j??5??6b??u???@o??~??KKZ???u\???sq{???Mz???M???h??rz???}=*|???L???z??hC?? \N???>p??(???R?? ???u&???R`???S ??dG ???E%??
Question:
Is there a way to process the data stream after it is decrypted?
