After upgrading from 13.1.1.4, we hav problems running the simplest of iRules for example :
if { [HTTP::uri] equals “/” or [HTTP::uri] equals “” }{
HTTP::redirect “https://[HTTP::host]/overview”
pool secure_pool
I logs in the LTM log like this: <HTTP_REQUEST> - Can’t call after responding - ERR_NOT_SUPPORTED (line 1) invoked from within “HTTP::host”
Any idea anyone?
//B
Lidev
January 29, 2020, 1:14pm
2
Hi Bunkemannen,
Check the bugID ID737252 and read this myF5
Regards
You probably has responded the request on another policy or iRule.
Take a look on this: HTTP::has_responded
if { [HTTP::has_responded] } {
return
if { [HTTP::uri] equals "/" } {
HTTP::redirect "https://[HTTP::host]/overview"
pool secure_pool
Regards.
OK We have a number of irules on the VS could it be the issue maybe, because this is working in Test where we have the same irules but not the same combination on the VS, thanks for the info!
Sajid
January 29, 2020, 6:16pm
5
Faced similar issue with v14.
Fixed the issue with “Local Traffic Policy”
