Irule problem
Hi iam trying to combine a couple of functions into one irule, the irule should look at the origin land
of the request allowing only countries i a specific data list and then look at the the ip to see if it is trusted
ip in the trusted ip data list (which allows access) and then last of all should look at the requested uri and if
the uri includes /compass and is from a ip that comes from Denmark it should be sent to a specific pool.
My atttempt at this is below, as iam a begineer at this, i have a problem th syntax seems okay but the irule does not seem
to work.
Any help or suggestions greatly appreciated.
when CLIENT_ACCEPTED {
if {([class match [whereis [IP::client_addr] country] eq allowed_country] or [class match [IP::client_addr] eq allowed_ip])} {
set allowed 1 }
else { set allowed 0
log local0. “Blocked Country client IP: [IP::client_addr] from [whereis [IP::client_addr] country]”}}
if { ([$allowed eq 1] and [whereis [IP::client_addr] country ] eq “dk” and [[HTTP::uri] contains “/compass/*”])}{
pool Compass_http_pool}
else {pool OnDemand_htp_pool}}
Regards Craig
Which parts aren’t working?
This part works if i remove the log local :-
set allowed 1 }
like:-
set allowed 1 }
else { set allowed 0 }}
But the bottom part does not work either :-
So iam cheking the ip´s first against two data lists one that is called allowed ip´s and one thats allowed countries and allowing certain ip´s and
countries through but (and i would like to log the traffik) but then if one of the urls includes /compass/ and is from denmark then it should be sent to
a seperate pool all others to the default pool.
Iam afraid iam not so accomplished with the syntax.
Regards Craig
if { $allowed eq 1 and [whereis [IP::client_addr] country ] eq "dk" and [HTTP::uri] contains "/compass/" } {
} else { pool OnDemand_htp_pool }
See if that compiles/works.
I haven’t looked at the client_accepted statement too much yet, but give this a shot.
    if { ([class match [whereis [IP::client_addr] country] eq allowed_country] or [class match [IP::client_addr] eq allowed_ip]) } {
          set allowed 1
 log local0.  "Blocked Country client IP: [IP::client_addr] from [whereis [IP::client_addr] country]"
set allowed 0 }
