Irule problem "contains then insert"
Hi Guys,
Looking to add an irule to fix a code issue until it can be fixed by the software team
when a request is made that contains native-billing i would like it to insert header named x-version with the value of 9.0
we have tried
when HTTP_REQUEST { if {{ [HTTP::uri] contains “native-billing” }} { HTTP::header insert “X-Version” “‘9.0’” }
didnt work Any ideas
thanks is advance
Do you get any error when adding the iRule to the system? Do you get any error when the iRule is executed?
I don’t see any major error in the iRule, except the double {. However, that shouldn’t cause problems.
Try add some log messages, like this:
  log local0. "[HTTP::uri]"
  if { [HTTP::uri] contains "native-billing" } {
    HTTP::header insert "X-Version" "'9.0'"
    log local0. "Header inserted"
  log local0. "Headers: [HTTP::header names]"
figured it out didnt like the “‘9.0’”
Changed to this and works
when HTTP_REQUEST { if { [HTTP::uri] contains “native-billing” } { HTTP::header insert “X-Version” “9” } }
