After upgrading from v9 to v11.2, irule got some problem.
before upgrade
class http_list {
“abc.com abc-r.com abc-r_pool”
“xyz.com xyz-r.com xyz-r_pool”
“123.com 123-r.com 123-r_pool”
set rp_list $::http_list
set host [HTTP::host]
set proxy_host_entry [findclass [string tolower $host] $rp_list]
if { $proxy_host_entry ne “” } {
set rp_host [getfield $proxy_host_entry " " 2]
set rp_pool [getfield $proxy_host_entry " " 3]
HTTP::header replace “Host” $rp_host
pool $rp_pool
After upgrade
ltm data-group internal /Common/http_list {
records {
“abc.com abc-r.com abc-r_pool” { }
“xyz.com xyz-r.com xyz-r_pool” { }
“123.com 123-r.com 123-r_pool” { }
type string
However should I convert the irule to work in v11.2?
nitass
2
can you create pool starting with numeric i.e. 123-r_pool?
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm data-group internal http_list
ltm data-group internal http_list {
records {
"abc.com abc-r.com abc-r_pool" { }
"xyz.com xyz-r.com xyz-r_pool" { }
type string
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.19.252:80
ip-protocol tcp
mask 255.255.255.255
profiles {
http { }
tcp { }
rules {
myrule
snat automap
vlans-disabled
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
if {[class search -- http_list starts_with [HTTP::host]]} {
set rec [class search -name http_list starts_with [HTTP::host]]
HTTP::header replace Host [getfield $rec " " 2]
pool [getfield $rec " " 3]
log local0. "[HTTP::host] | $rec | [getfield $rec " " 2] | [getfield $rec " " 3]"
[root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm
Oct 10 15:22:14 tmm info tmm[8764]: Rule /Common/myrule : abc.com | abc.com abc-r.com abc-r_pool | abc-r.com | abc-r_pool
Oct 10 15:22:16 tmm info tmm[8764]: Rule /Common/myrule : xyz.com | xyz.com xyz-r.com xyz-r_pool | xyz-r.com | xyz-r_pool
Thanks for your reply nitass. I will try that.
Those are just dummy names
