Is it better to have 10 different irules applied to the same virtual server that do similar thing or is it better to combine in one script? Or either way doesn’t matter? Eg pseudo scripts with 26 irules:::
irule A: if (src ip 10.1.1.1) then pool A
irule B: if (src ip 10.1.1.2) then pool B
irule Z: if (src ip 10.1.1.26) then pool Z
Or is it better to do:
just 1 irule:: if (src ip 10.1.1.1) then pool A else if src ip 10.1.1.2) then pool B… else pool Z (or do a case statement for this in a single irule)
if we code the irule something like this, will a number of irule reduce?
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.65.152:http
ip protocol tcp
rules myrule
[root@ve1023:Active] config b rule myrule list
rule myrule {
when CLIENT_ACCEPTED {
if {[class match -- [IP::client_addr] equals xyz]} {
log local0. "client is [IP::client_addr]:[TCP::client_port], action is [class match -value [IP::client_addr] equals xyz]"
[root@ve1023:Active] config b class xyz list
class xyz {
network 172.28.19.0/24 { "action2" }
host 192.168.204.7 { "action1" }
[root@ve1023:Active] config tail -f /var/log/ltm
Nov 15 08:48:30 local/tmm info tmm[4766]: Rule myrule : client is 192.168.204.7:54379, action is action1
Nov 15 08:48:38 local/tmm info tmm[4766]: Rule myrule : client is 172.28.19.253:59039, action is action2
Also, when the iRUles are combined, the namespace is shared. So a variable called $MyVar in iRule1 will be the SAME variable in iRule2…
e.g. If you init to 1 in CLIENT_CONNECT in both iRule1, then to 2 in CLIENT_CONNECT in iRule2, when HTTP_REQUEST fires in iRUle 1, the variable will have the value of 2… Not 1…
I have seen instances where the first iRule contains nothing but the variable settings used in all of the other attached iRules (so that if there was a Variable Change it only had to be made in a single iRule instead of every iRule attached to a Virtual Server.
