iRule patter based encrypted cookie
I have been trying to figure out a way that I can use a single iRule to apply to many Virtual Servers to encrypt my cookie.
I have tried following the a couple KB articles and they do not seem to work. When i apply the following iRule to my Virtual Server it breaks it and doesn’t load the page. Any suggestions on how to accomplish this?
when RULE_INIT {
Cookie name prefix
set static::ck_pattern "BIGipServer*"
 Log debug to /var/log/ltm? 1=yes, 0=no)
set static::ck_debug 1
 Cookie encryption passphrase
 Change this to a custom string!
set static::ck_pass "Test123"
} when HTTP_REQUEST {
if {$static::ck_debug}{log local0. "Request cookie names: [HTTP::cookie names]"}
 Check if the cookie names in the request match our string glob pattern
if {[set cookie_names [lsearch -all -inline [HTTP::cookie names] $static::ck_pattern]] ne ""}{
     We have at least one match so loop through the cookie(s) by name
    if {$static::ck_debug}{log local0. "Matching cookie names: [HTTP::cookie names]"}
    foreach cookie_name $cookie_names {
         Decrypt the cookie value and check if the decryption failed (null return value)
        if {[HTTP::cookie decrypt $cookie_name $static::ck_pass] eq ""}{
             Cookie wasn't encrypted, delete it
            if {$static::ck_debug}{log local0. "Removing cookie as decryption failed for $cookie_name"}
            HTTP::cookie remove $cookie_name
    if {$static::ck_debug}{log local0. "Cookie header(s): [HTTP::header values Cookie]"}
} when HTTP_RESPONSE {
if {$static::ck_debug}{log local0. "Response cookie names: [HTTP::cookie names]"}
         Encrypt the cookie value
        HTTP::cookie encrypt $cookie_name $static::ck_pass
    if {$static::ck_debug}{log local0. "Set-Cookie header(s): [HTTP::header values Set-Cookie]"}
Hi Jokragly,
the iRule below is at least working for me…
when RULE_INIT {
     Cookie name prefix
        if {$static::ck_debug}{log local0. "Matching cookie names: $cookie_names"}
Note: Checked corrected some formatings and changed the "Matching cookie names"line.
[log]
Mon Feb 22 22:40:23 CET 2016     info    f5-02   tmm[2649]       Rule /Common/iRule_2_Delete : Set-Cookie header(s): {BIGipServerwww.itacs.de=!CGOtVQL7P+nj19+TSJ8pqJQSLtu5dFey0o2aYmp8+zLRyY2cUVC18DA2xdis4A4LWyZe97t2HR419/DaFZkLsQrfuZ7iRbTOg7ji8Ohm; path=/; Httponly; Secure}
Mon Feb 22 22:40:23 CET 2016     info    f5-02   tmm[2649]       Rule /Common/iRule_2_Delete : Matching cookie names: BIGipServerwww.itacs.de
Mon Feb 22 22:40:23 CET 2016     info    f5-02   tmm[2649]       Rule /Common/iRule_2_Delete : Response cookie names: BIGipServerwww.itacs.de
Mon Feb 22 22:40:23 CET 2016     info    f5-02   tmm[2649]       Rule /Common/iRule_2_Delete : Cookie header(s): {ASP.NET_SessionId=jdkq3zcgwi22yx3ai1cotaqb; ASP.NET_SessionId_HMAC=0CEsmi1j37fbUwv27pg0TKoGy3HYeIFnDWOrqUF4sOI=; BIGipServerwww.itacs.de=rd1o00000000000000000000ffffd96e6c98o443}
Mon Feb 22 22:40:23 CET 2016     info    f5-02   tmm[2649]       Rule /Common/iRule_2_Delete : Request cookie names: ASP.NET_SessionId BIGipServerwww.itacs.de ASP.NET_SessionId_HMAC
Cheers, Kai
