iRule or LTM Policy to pre-fix desired www. sites
I have an issue where if I browse to https://abc.com the page will not load ( connection timed out) but https://www.abc.com will load as desired.
Therefore, I believe I need to somehow modify the following iRule to check to see if it contains www. and if it doesn’t add it.
 if { [class match [HTTP::host] equals Datagroup1] } {
  pool prod_sites
  HTTP::respond 403
However, I have a couple URIs in the data group that contains a subdomain that I don’t want to prefix with www.
I know I can change it with the following but I’m struggling to determine a way to redirect those in Datagroup1 with exceptions. I’m assuming its going to be a messy if, elseif, else kinda of deal but having a hard time putting it all together and working.
    if {[HTTP::host] eq "abc.com"} {
        HTTP::redirect "https://www.abc.com[HTTP::uri]"
maybe specifying a not equal for exclusions ??
if { ([HTTP::host] ne "subdomain.cbs.com") } {
I also currently have a policy in place to redirect HTTP to HTTPS as follows:
Redirect to location 'tcl:https://[getfield [HTTP::host] : 1][HTTP::uri]' at request time.
Any suggestions would be greatly appreciated.
What is the reason in your example that https://abc.com doesn’t work? Is it because there isn’t a DNS-record? In that case you could use the RESOLVER::name_lookup to see if it’s a valid record. If not, add www. to it.
See: RESOLVER::name_lookup (f5.com)
To be honest I’m not sure. I do see that abc.com and www.abc.com resolves differently but I feel like its something to do on Akamai as the traffic hits there before it gets directed to the F5 VS.
Looking at this more, http://abc.com, http://www.abc.com and https://www.abc.com all work. Just not https://abc.com nor does it redirect.
Okay, then it seems abc.com and www.abc.com are different sites and abc.com isn’t configured to handel HTTPS traffic. In that case you are probably better of using two datagroups. One datagroup that lists all allowed hostnames and another that contains hostnames that should be excluded from having put www. to it. Then let the iRule decide if it’s allowed and/or it’s needs to be modified with the start of www.
Understood. I created a new datagroup Datagroup_exclude and placed the subdomain sites in it. I guess I went full circle back to my original question now though. How would you go about checking to see if it needs to be modified with www and exlude those in the new datagroup?
@DoubleJz Can you provide a few examples of ones that would need to be excluded and which ones wouldn’t? Also, if https://abc.com/ doesn’t work but https://www.abc.com/ does work most likely all paths associated to just “abc.com” will not work because the root doesn’t work. You really should look into where “abc.com” and “www.abc.com” point to and what host they are listening for in your web server configuration.
What about this solution? Use the same Datagroup1, and define the allowed hosts as ‘strict’ if they shouldn’t be modified by the iRule. In the example below ‘nielske.nl’ isn’t allowed to be modified.
And use Datagroup1 with the following iRule.
    if { !([HTTP::host] starts_with "www.") && !([class lookup [HTTP::host] Datagroup1] equals "strict") } {
      log local0. "[HTTP::host] doesn't starts_with www. and isn't defined as strict; redirect allowed"
      HTTP::redirect "https://www.[HTTP::host][HTTP::uri]"
  HTTP::respond 403
I like that and thats similar to what I was trying to come up with prior posting on here. Also to be clear, the inner if statement doesn’t need an else. It if doesn’t match any constraints it will just leave that inner if statement and continue on in the outter if statement, right?
    pool prod_sites
  HTTP::respond 403
Yes, this looks alright to me.
