Does anyone know if there is an iRule command to add/remove a node/member to a pool.
Also do you know if there is a way to obtain the status/value of a server that is being polled via SNMP for a monitor ?
Does anyone know if there is an iRule command to add/remove a node/member to a pool.i do not think there is. anyway, you can send traffic to specific node by using “node” command.
node wiki
Also do you know if there is a way to obtain the status/value of a server that is being polled via SNMP for a monitor ?do you mean how to get pool member/node status in irule? if yes, is LB::status usable?
LB::status wiki
