iRule Optimization help
I have this iRule that works, but it seems there should be a way to do this more efficiently. Can anyone help out with this? I don’t know if the switch command would be of an value here.
when CLIENT_ACCEPTED {
if {[
matchclass [IP::local_addr] equals $::NG_Bypass_IP] or [active_members NG_Pool] == 0 and [active_members Cache_Pool] == 0 or not [matchclass [IP::client_addr] equals $::NG_Clients] } {
forward
elseif {
[active_members NG_Pool] > 0} {
pool NG_Pool
elseif {
[active_members Cache_Pool] > 0 and not [matchclass [IP::local_addr] equals $::Cache_Bypass_IP]} {
pool Cache_Pool
else {
forward
when LB_FAILED {
reject
From what i see i don’t see how the switch is going to work for you. However, what you can do is check is how well it is evaluating the irule. Click here if you want to take a look at “timing on” which allows you to collect statistics.
