Irule not working
Below is my irule is not working if the URI::query doesn’t have the required parameters. Basically i want send respond 200 for successful connection and 401 for incorrect parameter or non parameter Please suggest
when HTTP_REQUEST { HTTP::header insert “clientless-mode” 1 log local0. “clientless-mode 1” set xyz [HTTP::query]
if {[info exists $abc]} { HTTP::respond 200 content $abc }
when ACCESS_POLICY_COMPLETED { if {[ACCESS::policy result] equals “allow”} {set abc [class match -value “$xyz” equals USERS_DG] ACCESS::respond 200 content “$abc” log local0. “$abc”} if{not([class match -value [“$xyz”] equals USERS_dg ] ) } {ACCESS::respond 401 content “TEST”}
Slightly easier to read formatting:
  HTTP::header insert "clientless-mode" 1
  log local0. "clientless-mode 1"
  if {[ACCESS::policy result] equals "allow"} {
    set abc [class match -value "$xyz" equals USERS_DG]
    ACCESS::respond 200 content "$abc"
    log local0. "$abc"
  if {not([class match -value ["$xyz"] equals USERS_dg ] ) } {
    ACCESS::respond 401 content "TEST"
Just a quick rewrite:
    set xyz ""
    if { $xyz ne "" } {
        log local0. "ACCESS_POLICY_COMPLETED: Found query string $xyz."
            set abc ""
            set abc [class match -value -- "$xyz" equals USERS_DG]
            if { $abc ne "" } {
                log local0. "ACCESS_POLICY_COMPLETED: $abc : access allowed"
                ACCESS::respond 200 content $abc
                event disable all
                return
                log local0. "ACCESS_POLICY_COMPLETED: param not matching acl: access not allowed"
                ACCESS::respond 404 "resource not found."
                event disable all
                return
        log local0. "ACCESS_POLICY_COMPLETED: query string not found."
        event disable all
        return
when HTTP_REQUEST { set xyz “” HTTP::header insert “clientless-mode” 1 log local0. “clientless-mode 1” set xyz [HTTP::query] }
when ACCESS_ACL_ALLOWED { set abc “” set abc [class match -value -- “$xyz” equals USERS_DG] if { $abc ne “” } { log local0. “ACCESS_POLICY_COMPLETED: $abc : access allowed” HTTP::respond 200 content $abc event disable all return } else { log local0. “ACCESS_POLICY_COMPLETED: param not matching acl: access not allowed” HTTP::respond 404 “resource not found.” event disable all return }
if { $abc eq "" } {
    HTTP::respond 401 content "Error: Failure in Authentication" Connection Close
    event disable all
    return
When working with clientless mode, there is no more interractivity with requestor.
You have to define in the irule how do you get credentials for policy evaluation.
There are some irule on devcentral on how to manage clientless mode like basic authentication, xml parameter or certificate.
How do you want the client authenticate in APM?
