IRule not working - sytnax error or something else?
I have tried writing my first iRule to check the url of my site and then depending on which site the user is attempting to access, I then check a list of approved IP addresses.
If the clients IP address is not found in the list, I redirect them to an unauthorised page, otherwise I let them through.
This is my code:
switch -glob [string tolower [HTTP::uri]] {
“*XXX*” {
if not { matchclass [IP::client_addr] equals $::XXX_access_list } {
HTTP::redirect https://MyXXXUnauthPage.com
“*YYY*” {
if not { matchclass [IP::client_addr] equals $::YYY_access_list } {
HTTP::redirect https://MyYYYUnauthPage.com
“*ZZZ*” {
if not { matchclass [IP::client_addr] equals $::ZZZ_access_list } {
HTTP::redirect https://MyZZZUnauthPage.com
Is there a syntax error here or have I just gor my logic wrong.
Any help would be GREATLY appreciated.
Try this:
"*XXX*" {
if { !([matchclass [IP::client_addr] equals $::XXX_access_list]) } {
        "*YYY*" {
            if { !([matchclass [IP::client_addr] equals $::YYY_access_list]) } {
        "*ZZZ*" {
            if { !([matchclass [IP::client_addr] equals $::ZZZ_access_list]) } {
Your not comparison (can also be expressed by “!”), needs to be inside of your if statement and needs to be applied to the entire comparison.
Comparison: [matchclass [IP::client_addr] equals $::ZZZ_access_list]
Comparison: !(results of first comparison)
Result: if false, do this…
Hi Michael, thanks for your quick feedback.
I’ve just applied the changes with your recommendations, but it appears we’re still having problems with the matchclass aspects. I wanted to state that I created “site_access_list” as a Data Group in the BIGIP UI. It contains multiple Host and Network addresses. Anything I should be considering on that?
Code looks like:
        "*client*" {
            if { !([matchclass [IP::client_addr] equals $::site_access_list]) } {
HTTP::redirect https://site
If you’re on 9.4.4 or higher you should remove the $:: prefix from the datagroup name. It will demote the iRule from CMP in any version, but won’t work at all to access the datagroup in v10+:
http://devcentral.f5.com/wiki/default.aspx/iRules/CMPCompatibility.html
For 10.x you should also change from matchclass to the class match command for better efficiency:
http://devcentral.f5.com/wiki/default.aspx/iRules/class
Aaron
