iRule not working since upgrading to 11.2
Apologies if a similar question has been asked and answered. I searched the forum but couldn’t find anything. I have an irule that references a data group for blocking spiders by user-agent (I copied it from a rule posted previously on DevCentral). The rule is:
if { [matchclass [HTTP::header “User-Agent”] contains $::UserAgentBlacklist ] } {
drop
return }
The Data Group is a string data gorup called UserAgentBlacklist with a series of entries:
80legs
snitch
Yandex
discobot
It worked nicely in 10.2, but after upgrading to 11.2, I’m getting:
tmm err tmm[11342]: 01220001:3: TCL error: /Common/UserAgent-Blacklist_irule - can’t read “::UserAgentBlacklist”: no such variable while executing "matchclass [HTTP::header “User-Agent”] contains $::UserAgentBlacklist
Any chance it’s something obvious in the syntax that’s changed with 11.x?
You need to convert over to class command the matchclass command is deprecated in v10. it is a easy change
e.g.
   if { [class match -- [HTTP::header "User-Agent"] equals UserAgentBlacklist ] } {
      drop
Wow, that was toooo easy. Thanks so much for the exceptionaly quick reply!! I made the change and it’s working great. Cheers!
It was the $:: prefix breaking the iRule on 11.x.
Adding to Niass’ suggestion, you could also add your user-agent strings in lower case to the data group and then set the User-Agent header value to lower case in the iRule:
   if { [class match -- [string tolower [HTTP::header "User-Agent"]] equals UserAgentBlacklist ] } {
      drop
Aaron
Ahh, that’s a good idea. Thanks, I’ll do that.
Everything I read didn’t say “matchclass” would stop working in 11.X - in fact it works in bothe VE 11.2.0 and on production hardware at 11.2.0 (documented as less performant). In fact the DevCentral (never said it stopped working) it only says:
The class command deprecates the findclass and matchclass commands as it offers better functionality and performance than the older commands. Note that you should not use a $:: or :: prefix on the datagroup name when using the class command (or in any datagroup reference on 9.4.4 or later). For details, see the CMP compatibility page.
Yes I agree with hoolio the $:: prefix on data groups was breaking (also noted in the above) my iRules on 11.x two weeks ago - thank goodness for a 11.2.0 VE to debug this stuff - I figured it out on my own in case C1171849 on 7/30/2012 where I ended up using a ‘sed’ pipline to fix my /config/bigip.conf file (all iRULEs) in mass. The added benefit is that my globals became CMP compliment.
I did this on a F5 system running version 10.2.0 prior to upgrading it to version 11.2.0 as follows (special note all my datagroups start with g_dg_ so LOOK hard at the sed command - don’t blindly run it):
backup up the config
cp -p /config/bigip.conf /config/bigip.conf.sav
 make sure '::' only exists in iRULEs blocks
grep '::' /config/bigip.conf.sav
 alter the syntax to 11.X CMP compliance via a sed pipeline
cat /config/bigip.conf.sav  | \
  sed -e 's/set ::/set static::/g' | \
  sed -e 's/incr ::/incr static::/g' | \
  sed -e 's/info exists ::/info exists static::/g' | \
  sed -e 's/\$::/$static::/g' | \
  sed -e 's/\$static::g_dg/g_dg/g' > \
  /tmp/bigip.conf.new
Manually change old “matchclass” to new “class match” for more performance on my data groups
grep 'matchclass' | grep g_dg /config/bigip.conf.new
        if { [matchclass [IP::client_addr] equals g_dg_handset] } {
        if { [matchclass [IP::client_addr] equals g_dg_other] } {
        if { [matchclass [IP::client_addr] equals g_dg_dongle] } {
 use “vi” editor alter the above to 'class match'
vi /tmp/bigip.conf.new
 verify change
grep 'class match' /config/bigip.conf
        if { [class match [IP::client_addr] equals g_dg_handset] } {
        if { [class match [IP::client_addr] equals g_dg_other] } {
        if { [class match [IP::client_addr] equals g_dg_dongle] } {
 install and make active this 10.2.0 syntax, in 11.x you  need to use a tmsh command
cp /tmp/bigip.conf.new /config/bigip.conf
b load
I ended up going with:
   if { [class match [string tolower [HTTP::header "User-Agent"]] contains UserAgentBlacklist ] } {
      drop
