irule not redirect with wildcard.
when i try to redirect (wildcard) https://www.abc.com//index.cfm?ty=dir or https://www.abc.com//index.cfm?ty=fua, it is not redirect, do you know what happening with my irule? i appreciate your reply:
if { [HTTP::host] equals “www.abc.com” }
switch -glob [HTTP::path]
“/index.cfm?ty=dir”
{ HTTP::respond 301 Location “https://cbs.com/redir-legacy/index.cfm?ty=dir”
“/index.cfm?ty=fua”
{ HTTP::respond 301 Location “https://cbs.com/redir-legacy/index.cfm?ty=fua”
{ HTTP::respond 301 Location “https://cbs.com/redir-legacy/”
default
return
Hi Hien,
your iRule is not redirecting because HTTP:path is only index.cfm. The ty=dir is the query parameter and is in the HTTP::query command. The query is defined as the part of the request past the ? character. See below image for explanation.
Maybe you can do the check in a different way. Use the switch statement for the HTTP::path and use a nested if / else statement for the HTTP::query. Check this out for examples: https://devcentral.f5.com/s/articles/irules-101-13-nested-conditionals
KR
Daniel
Man, I am blind. You could also use HTTP::uri which contains both, the path and the query parameter…
​Daniel,
you are correct, when I change to HTTP:uri, it works. Thanks a lot for your support.
