iRule not executing
Upgraded to v11.5.1 with Hotfix-HF2. created first new pool & virtual and assigned a HTTP Redirect iRule :
when HTTP_REQUEST { if { [HTTP::uri] equals “/” } { HTTP::redirect “http://crm.murrob.com:5555/murrayroberts” } }
both pool and VS service port set to 5555
however it does not re-direct and when I look at the iRule statistics I see 0 Executions…
I have many other exact re-direct rules (different service ports & url) and they work.
any suggestions will be appreciated
Is a HTTP profile assigned to the VS?
if you run curl on bigip, is it executed?
curl -I http://virtual_server_ip/
Perhaps some additional logging?
    log local0. "incoming URI = [HTTP::uri]"
    if { [HTTP::uri] equals "/" } {
        log local0. "catch and redirect for /"
        HTTP::redirect "http://crm.murrob.com:5555/murrayroberts"
curl: (7) couldn’t connect to host - however both pool & VS are green
sorry i forgot port number. curl -I http://virtual_server_ip:5555/
Strange .. it only appends triple 5 and not 5555 HTTP/1.0 302 Found Location: http://crm.murrob.com:555/murrayroberts Server: BigIP Connection: Keep-Alive Content-Length: 0
Checked all the other rules- all of them only has 3 digit port numbers and not 4 …
it seems okay here.
test
[root@ve11a:Active:In Sync] config  curl -I http://172.28.24.10:5555/
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
 config
[root@ve11a:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
it seems okay here.
test
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
 config
ltm rule qux {
okay my mistake - made a typo, both curl and tmsh list outputs shows the four digit port number - however still no redirect
if curl shows redirection correctly but it still does not work, you may have to try tcpdump on bigip and/or http analyzer tool on client to see where the wrong is.
HttpFox
https://addons.mozilla.org/en-US/firefox/addon/httpfox/
for tcpdump, you may try this.
tcpdump -nni 0.0:nnnp -s0 -w /var/tmp/output.pcap host x.x.x.x -v
x.x.x.x is client ip
HttpFox
did the tcpdump and the source port (me) is a random high port, destination port is 80 - this tells me the iRule does not execute?
