I currently use the below iRule with our Terminal Services pool. It strips everything after the “@” in the username so that the persistence entry is only the username. I would like to modify it so that usernames that are entered in the form “domain\username” are also entered in the table with just the username. In toehr words I weould like the iRule to strip out everything before the “/”. How would I do this? Can someone help?
Feb 2 14:23:33 tmm tmm[31729]: Rule sso_username : Data Persisting on: danaip
See how one of the entries stroes only chbghosp\. I want to strip that part so that we can get the username instead of the domain. Another issue we are having is that it persists usernames stripped of @summithealth.local as seperate entries than usernames entered with just the username. For example, if I log into a 2X thin client I am logged in as jmasgalas@summithealth.local. The iRule srtips it down to jmasgalas and created a persistence table entry. I then rdp to the VIP from my desktop which sends the username as jmasgalas. The F5 is creating two different persistence table entries names jmasgalas. If you need it I can send you the contents of the persistence table.
You should be able to check for the presence of the backslash, and if present, split on it and take everything in the second field as your persistence value. If you just want the username, and not the @…, you could do a secondary split on the @ and keep the first field.
You can use something like this to parse them down to the account name:
if {$account contains "@"}{
set account [getfield $account "@" 1]
} elseif {$account contains "\\"}{
Need to escape the backslash with a backslash
set account [getfield $account "\\" 1]
OK. So I took hoolio’s idea and came up with the below iRule. However it strips everything after the \ instead of before. So a username of domain\username becomes domain.
It seems that with this rule it persists the value but as seperate entries. Also the stripping everything before \ is not creating a persistence table entry. When I ssh to our F5 here is what the output of b persist show all | grep doctest is:
[root@bigbrother:Active] config b persist show all | grep doctest
Mode: universal Value: doctest
Here is the log file:
Feb 6 13:01:45 tmm tmm[31729]: Rule ssotest2 : Contents after binary scan: Cookie: mstshash=doctest
Feb 6 13:01:45 tmm tmm[31729]: Rule ssotest2 : Data Persisting on: doctest
@Hoolio, if I recall correctly the len variable includes the “=”, so it is decremented to remove the additional character that would otherwise be included in the persist string.
log local0. “Setting data to: [getfield $msrdp “@” 1]”
set username [getfield $msrdp “@” 1]
} elseif { $msrdp contains “\\” } {
log local0. “Setting data to: [getfield $msrdp “\\” 3]”
set username [getfield $msrdp “\\” 3]
set username $msrdp
log local0. “Setting data to: $msrdp”
set finalusername [string tolower $username]
set finalusername [string trim $finalusername]
log local0. “User Being Persisted is: |$finalusername|”
persist uie $finalusername 10800
TCP::release
The only thing is that 9 character limit. I know this is an MS TS limitation but is ther a way around it. Thanks for all your input and help though. You have steered my in the right direction!
Hi all, thought I’d add something to the mix here, mainly for information purposes in case anyone else is in my boat - although if anyone does have a nugget of info then that would be great.
I’m on LTM v9.0.x - thought this iRule would save the day but doesn’t look like it works with this old code. Out of the 3 possible login situations username, username@company.org and domain\username, the only one it worked for was the username@company.org login type. The other 2 produced 2 persistence entries for one login and looking as follows: either username r??? or domain r??? (or some gobbledigook like that). In addition the persistence was not 100%.
One day I’ll be given shiny new v10 appliances…until then.
