iRule LX feature
Guys, how do I get the iRule LX feature? I went through some videos and found that it needs to be enabled in the “Resource Provisioning”. However, the option to enable is not there. Is it an additional license?
Or is it some plugging that needs to be installed? If a plugging, where can I find it?
You need to have TMOS 12.1.0 or above and no license is required but you will also not get any F5 support other than F5-provided API.
See K16221101: Overview of iRules LX properties and limitations
You need to have TMOS 12.1 above. You don’t have to purchase extra licensing, but if you have an older license file (such as from a previous version of Big-IP), you may need to re-active your license (under System → License) to make sure that the part enabling iRulesLX is in your license file.
Also, you will need to provision iRulesLX (System → Resource Provisioning). Even if licensed, it will not show up in any of the menus until you do that.
Yes, you have to go to System > Resource Provisioning and the enabled it, but should already be licensed.
