I’ve been tasked with investigating the possibility to whitelist traffic from source IP addresses that are matched against a remote list, implemented as an API endpoint that returns a json array of permitted CIDR addresses.
Incoming traffic would arrive on the bigip, the source address would be matched through an iRule that would look up the address against a remote API endpoint containing whitelisted addresses and if there is a match it would pass the traffic, if not, return unauthorized.
I wanted to see if anyone in the F5 community has tried to implement such a function? The closest post I have come across (from 2007) is here.
I am aware the source data would usually go in a data group, or a remote data group but I have no way of transferring a remote list onto the F5. Even if I did that list would have to be updated on a frequent schedule.
I am also aware of the downsides to any approach to have an iRule make a remote call out (blocking, zero data returned, API call made for each connection etc) but as I say it is just research at this point. It might well be that it is simply not a feasable task.
Thanks, Will.
