The question here was how to log a lb failure (no nodes available) but not on every connection. It would preferably log an error every 50 lb failures.
unRuleY responded with the following rule that will go a step further and create an array that will store counters for each pool. And then, for each pool, it will log only on the 50th lb failure.
when RULE_INIT {
# Initialize the counter to 0.
array set ::log_ctr { }
when LB_FAILED {
if { [LB::server addr] eq "" } {
set pool [LB::server]
if { not [info exists ::log_ctr($pool)] or $::log_ctr($pool) >= 50 } {
log "No nodes available - pool $pool"
set ::log_ctr($pool) 0
incr ::log_ctr($pool)
Click here for the original thread.
[Listening to: The Hanging Garden - The Cure - Staring at the Sea: The Singles (04:22)]
