I just upgraded a pair of LTM’s to 9.4.1 from 9.1.2 HF5 and I no longer see my iRules (log local0. “xxx”) logging to /var/log/ltm, or anywhere else for that matter. I checked to make sure mcpd logging was set to notice, and yet still no irule logs. I thought all logging was impacted, but I see audit logs now have their own file. Is this a no-brainer that someone else has experienced in the move from 9.1.x to 9.4.x, or should I press support? TIA…
Was your /etc/syslog-ng/syslog-ng.conf file overwritten? Where is local0.info being directed to?
I haven’t seen any issues on 9.4.0 with syslog-ng logging from iRules. By default, any messages containing the string AUDIT should be logged to /var/log/audit. All other local0 messages should go to /var/log/ltm. Here is an example:
