I’m trying to modify an existing iRule below by creating a logic where it will parse the username being used, and load balance based on the username, while still using the HTTP::uri command. I know the below configuration does not work. The GUI throws an error when trying to execute this config. However, the logic goes something like the example config below. Can someone please advise if this is the best and easiest way to do this? What are my options and proper way to handle this? So usernames 1 - 3 would be sent to pool pool1, and everyone else, gets sent to the default pool assigned to the VIP.
when HTTP_REQUEST { if { [HTTP::uri] equals “/” } { HTTP::uri /login/ pool default }
elseif { [HTTP::uri] equals “/” and [HTTP::username] contains “username1” or “username2” or “username3” } { HTTP::uri /3dspace/ pool pool1 } }
if { [HTTP::uri] equals "/" } {
HTTP::uri /login/
pool default
} elseif { [HTTP::uri] equals "/" and [HTTP::username] contains "username1" or [HTTP::username] contains "username2" or [HTTP::username] contains "username3" } {
HTTP::uri /login/
pool default
Thanks for the response Yann, but it doesn’t look like this iRule works. It is not load balancing username1 to pool1. The initial HTTP request will send me to pool default, which shows me a login page of the application, which is fine. However, when I log in with my credentials (i.e. username1), either the LTM does not see anything in the HTTP::username, or I’m not parsing the username string correctly. I’m not sure what is missing here. Any help would be appreciated.
If I understand correctly, your authentication process is a web login page. The HTTP::username command get the username from the Basic Authorization header so this irule can’t work for you. You have to parse the POST body of the login url to get the username. You can use the command HTTP::payload and HTTP::collect to retrieve the username.
There is an example in https://devcentral.f5.com/codeshare?sid=652 for how to handle HTTP username.
There is an example in DevCentral - An F5 Technical Community for how to handle HTTP username.
