Hello forum…
Has anyone upgraded to 11.3 HF1 yet?
I have just applied the update to my dev environment and my iRule broke. The following is what makes it die (and this is obviously a key component):
CLIENT_ACCEPTED { ACCESS::restrict_irule_events disable }
I get 404 not found issues.
Firefox tells me this in the WebConsole:
[10:46:14.192] The character encoding of the plain text document was not declared. The document will render with garbled text in some browser configurations if the document contains characters from outside the US-ASCII range. The character encoding of the file needs to be declared in the transfer protocol or file needs to use a byte order mark as an encoding signature. @ https://dev/my.policy
Would be interested to know if it is just me, or if this could be a bug. It all works fine in 11.3 without HF 1.
Thanks very much.
