Snl
October 30, 2016, 11:00am
1
I am trying to archive below but its not working
original request - https://abc.com/db/ap-webconsole before reach server it should go as https://abc.com:3333/ap-webconsole response should go as https://abc.com/ap-webconsole to client
Code
when HTTP_REQUEST { log local0. "Original path: [HTTP::path]"log local0. "Original uri: [HTTP::uri]"log local0. "host = [HTTP::host]; path = [HTTP::path]"
if { [HTTP::uri] starts_with "/db/ap-webconsole" } {
HTTP::path "[HTTP::host]:3333/ap-webconsole" log local0. "Pool app1 chosen" pool app1 log local0. "Modified uri: [HTTP::uri]" } else { log local0. "Pool app2 chosen" pool app2
any help appreciated
Thanks snl
in your irule, you get request parameters with good command, but when you change it, you only modified HTTP::path…
HTTP::host "[HTTP::host]:3333"
HTTP::path "/ap-webconsole"
another point is to replace /db/ap-webconsole with /ap-webconsole
HTTP::path [string map {/db/ap-webconsole /ap-webconsole} [HTTP::path]]
Snl
October 31, 2016, 4:01am
3
so can i try as below
Code
if { [HTTP::uri] starts_with "/db/ap-webconsole" }{
pool app1
else {
pool app2
still i am getting error on line 5 , how we can modify the host with :3333 or use respond location 301 because backend http host is change to something else do i required to modify the response as well with stream profile ? pls assist
try this irule:
switch -glob -- [HTTP::path] {
"/db/ap-webconsole*" {
HTTP::respond 301 noserver Location [string map {/db/ap-webconsole /ap-webconsole} [HTTP::uri]]
"/ap-webconsole*" {
HTTP::header replace Host "[HTTP::host]:3333"
default {
HTTP::respond 302 noserver Location "/ap-webconsole/"
