irule is taking wrong cookie
I am using the below irule for cookie based routing.
The irule is not taking the cookie value properly.I am observing cookies on my browser using HTTP Watch pro.
I see JTAP=POD25 in httpwatch pro and in Irule logs i see JTAP=POD2. I am not sure from where the irule is taking the value POD2. Could somebody please tell wheres wrong
if { [HTTP::cookie “JTAP”] ne “” } {
log local0. " Web tier: *** Found JTAP Cookie: [HTTP::cookie JTAP]"
set JTAP [string tolower [getfield [HTTP::cookie “JTAP”] “^” 3]]
pool p_$JTAP
log local0. “Web tier: *** Request went to $JTAP”
else {
pool p_default
Thanks for your help and have a Happy New Year
Hi Rupa,
Looking at your irule it appears that there are several items in JTAP? Something like “JTAP=value^value2^value3” and you are trying to extra the 3rd field? Just need to understand why you needed the getfield
Bhattman
Hi Bhattman,
Sorry my bad,
My cookie JTAP looks like pay^app^pod25. i am retriving the 3rd value from that.Because i named the pool with the 3rd value.
if you see the first log statement in my irule
I am logging the JTAP value. I am getting pay^app^pod2 in the logs.But in HTTP watch pro i see JTAP=pay^app^pod25
what could be the problem?
Regards,
Rupa
Hi Rupa,
The iRule looks straightforward enough. Can you post a sample from the ltm log for a failure?
Here is a quick test showing the parsing working correctly:
when RULE_INIT {
    set cookie "abc^def^ghi"
    log local0. " \$cookie: $cookie; \[getfield $cookie \"^\" 3\]: [getfield $cookie "^" 3]"
And the ltm log output:
Rule : $cookie: abc^def^ghi; [getfield abc^def^ghi “^” 3]: ghi
Thanks,
Aaron
Hi Rupa,
I was asking if you could post the log output from these two log lines:
log local0. “Web tier: *** Found JTAP Cookie: [HTTP::cookie JTAP]”
Also, can you clarify which host you captured the tcpdump. If it was on LTM, was it on the client or server VLAN?
Thanks,
Aaron
thanks for your reply,
there is no issue with F5.My webserver is truncating the cookie.
Glad you figured out the problem. Thanks for clarifying it.
Aaron
