irule is not working
I am trying to use following irule. Is there any thing on virtual server stop irule
when HTTP_REQUEST { if { [HTTP::uri] contains “services” } { log local0. “URI CONTAINS SERVICES” node 192.168.190.3 80 log local0. “SERVICE POOL” } } log shows Apr 11 15:00:45 CIODCDMZF5LTM02 info tmm4[10306]: Rule /Common/service.portal.redirect : URI CONTAINS SERVICES Apr 11 15:00:45 CIODCDMZF5LTM02 info tmm4[10306]: Rule /Common/service.portal.redirect : SERVICE POOL but actually request is not moving to node 192.168.190.3 80 while directly access node is fine. Please help
are you using oneconnect?
sol9800: Using an iRule to load balance HTTP requests to multiple pools
