iRule inspecting body response
Hello Devcentral community,
How i can detect if the following content of the HTTP BODY is present in the HTTP RESPONSE ?
the following line :
this.location.replace ("
Thanks in advance,
BG
I think you can do something like:
STREAM::disable
STREAM::expression "this.location.replace("https://"
STREAM::enable
Then use the STREAM_MATCHED event:
when STREAM_MATCHED {
  log local0. "Stream found."
You may need to play with it some, I can’t remember exactly how to do this, but it can be done. You can search with stream and then NOT replace.
Hello when i try to log the payload of the response i can see that the output is in the following “format” : Iû¥ç€°¨±%¯$CØ=û¿ß‘_±CÃ’$½ýÀ€Â¶Â¤Ã‘ÃŒhæ7y¸VÂ�Â�œáš
�*ª|âL±O$:@|E¥¢.¼¢)+!ú”�¢µ KÛXR o˜2ӕÒ@‚ø¶!Õfׄ(ÃJW�P!³U„WÄ6¾ã N& $…+«×뵒)ÙòA03¿KؚÎ9•Ê«¹È--y-6S<,_Cÿ·_Â)
³5ýezÅÜö8µŸ.
How i can scan it successfully ? I expect that the response is an html format response.
Thank you.
Two possibilities:
1) the server is compressing the response 2) what you are looking at is a binary file: gif, png, jpeg, pdf, or something else like those.
You should also be able to do this by using a Content Profile HTML Rule. It can trigger the corresponding event you can use in an iRule.
