iRule HTTPS to HTTPS redirection
Dear All,
I have a virtual server publishing a https://www.xpto.com website.
I need to redirect via irule the requests from the old site https://www.xpto.com to the new https://www.abc.com. The http redirection is working fine, but the https show a certificate error
Both have ssl profile.
Thanks, Marcelo
Can you share some more details? What kind of error do you get? When you browse to directly https://www.abc.com, do you get the same error? How did you configure the redirect?
ERR_CERT_COMMON_NAME_INVALID
Do I need to declare in irule the old site’s certificate profile to get around this error?
The vs of https://www.xpto.com uses the client profile xpto_ssl_profile and the old site (https://www.abc.com) used the abc_ssl_profile.
How can i fix this common name error?
if { [string tolower [HTTP::host]] ends_with ".abc.com" } {
    HTTP::redirect "https://www.xpto.com[HTTP::uri]"
If I understand correctly it seems your uses the wrong certificate. Can you login to your BIG-IP with ssh and show the output of the following commands?
curl -kv https://www.abc.com
 curl -kv https://www.xpto.com
I gave up trying the redirect on the same VS.
I created a new text with the profile of the old certificate doing the redirection.
