Currently we are using the F5 inbuilt iRule - _sys_https_redirect , we need a permanent redirection (respond code 301) . can I use belwo iRule ?
when HTTP_REQUEST { HTTP::respond 301 HTTP::redirect https://[getfield [HTTP::host] “:” 1][HTTP::uri] }
the irule must be:
HTTP::respond 301 Location https://[getfield [HTTP::host] ":" 1][HTTP::uri]
Thanks let me try it
Hi Stanislas,
I have tried it , redirection is happening but still the respond code is 302
I tried the same irule and it is my result:
$ curl http://abc.company.com -vv
* Rebuilt URL to: http://abc.company.com/
* Trying 2a02:aaaa:bbbb:cccc:f5::4...
* Connected to abc.company.com (2a02:aaaa:bbbb:cccc:f5::4) port 80 (0)
> GET / HTTP/1.1
> Host: abc.company.com
> User-Agent: curl/7.43.0
> Accept: */*
* HTTP 1.0, assume close after body
< HTTP/1.0 301 Moved Permanently
< Location: https://abc.company.com/
< Server: BigIP
* HTTP/1.0 connection set to keep alive!
< Connection: Keep-Alive
< Content-Length: 0
* Connection 0 to host abc.company.com left intact
Did you flush your browser cache?
HTTP 302 should not be cached by the client.
However, I would recommend using something like cURL for testing rather than a browser since it eliminates optimizations and most caching.
curl -I "http://www.domain.com/"
The flag
-I
instructs
cURL
to do a
HEAD
request, which makes it much easier to review the results. Keep in mind that
HEAD
sometimes returns a different response than
GET
