iRule HTTP::Redirect not working on some URLs (aborting connection)
Hi all,
I’m a bit stumped…
class SharePoint-Redirect_Urls_Old_Path_To_New_Path_DataGroup {
      "/ALL_ENTRIES_MUST_BE" { "LOWER_CASE_TO_MATCH" }
      "/cop/da-apt" { "/co/da-apt" }
      "/cop/hrp-prh" { "/co/hrp-prh" }
      "/cop/knowledge" { "/co/knowledge" }
      "/cop/ypn-rjp" { "/co/ypn-rjp" }
      "/projects-projets" { "/pj" }
      "/governance-gouvernance" { "/gv" }
      "/communities-communautes" { "/co" }
      "/search/" { "/search-recherche/" }
rule SharePoint-Redirect_Urls_Old_Path_To_New_Path {
when RULE_INIT {
    Set this option to 1 to log messages (to /var/log/ltm by default)
   set static::log_old_to_new_path_redir 1
when CLIENT_ACCEPTED {
    if {[TCP::local_port] eq 443} {
        set CLIENT_HTTP_TYPE "https"
        set CLIENT_HTTP_TYPE "http"
    set MATCH_FOUND [class match [string tolower [HTTP::path]] starts_with SharePoint-Redirect_Urls_Old_Path_To_New_Path_DataGroup]
    if {($static::log_old_to_new_path_redir) && ($MATCH_FOUND)}{
        set CLIENT_ADDR [IP::client_addr]
        set XFF [HTTP::header X-Forwarded-For]
        set ID "[TCP::local_port][expr { int(100000000 * rand()) }]"
         seconds from epoch + random number
        set ID "[TCP::local_port]-[clock seconds]-[expr { int(100000000 * rand()) }]"
        set REQUEST_RECEIVE [clock clicks -milliseconds]
        set HTTP_LPATH [string tolower [HTTP::path]]
    if {$MATCH_FOUND} {
        set KEY [class match -name $HTTP_LPATH starts_with SharePoint-Redirect_Urls_Old_Path_To_New_Path_DataGroup]
        set VAL [class match -value $HTTP_LPATH starts_with SharePoint-Redirect_Urls_Old_Path_To_New_Path_DataGroup]
        set REPLACED_PATH [string map -nocase [list $KEY $VAL] [HTTP::uri]]
        set REDIRECT_URL "$CLIENT_HTTP_TYPE://[HTTP::host]$REPLACED_PATH"
            log local0.info "URI_PATH:[HTTP::path] || KEY:$KEY || VAL:$VAL || REPLACED_PATH:$REPLACED_PATH || REDIRECT_URL:$REDIRECT_URL - SRC:$CLIENT_ADDR  ID:$ID"
        HTTP::redirect $REDIRECT_URL
when HTTP_REQUEST_SEND {
        set REQUEST_SEND [clock clicks -milliseconds]
        set REQUEST_WAIT [expr {$REQUEST_SEND - $REQUEST_RECEIVE}]
        log local0. "URI PATH: $HTTP_LPATH  - SRC:$CLIENT_ADDR  ID:$ID"
when HTTP_RESPONSE {
        set RESPONSE_TIME [expr {[clock clicks -milliseconds] - $REQUEST_SEND}]
        log local0. "URI PATH: $HTTP_LPATH - HTTP[HTTP::status] $RESPONSE_TIME\ms/$REQUEST_WAIT\ms [LB::server addr] - SRC:$CLIENT_ADDR ID:$ID"
The lines entries for projects to search in the data group all fail to redirect… I get a browser aborted.
However, the log entries show up as successful…
DOES actually redirect:
Rule SharePoint-Redirect_Urls_Old_Path_To_New_Path : URI_PATH:/cop/ypn-rjp/ || KEY:/cop/ypn-rjp || VAL:/co/ypn-rjp || REPLACED_PATH:/co/ypn-rjp/ || REDIRECT_URL:https://collab.MY_DOMAIN_HERE/co/ypn-rjp/ - SRC:10.128.42.207 ID:1458297076443-20424180
DOES NOT actually redirect (aborted)
Rule SharePoint-Redirect_Urls_Old_Path_To_New_Path : URI_PATH:/communities-communautes/cts-cst/ || KEY:/communities-communautes/cts-cst || VAL:/co/cts-cst || REPLACED_PATH:/co/cts-cst/ || REDIRECT_URL:https://collab.MY_DOMAIN_HERE/co/cts-cst/ - SRC:10.128.42.207 ID:1458297033443-17874026
The events HTTP_REQUEST_SEND and HTTP_RESPONSE never fire (no logging) which makes sense if the redirect is happening in the HTTP_REQUEST. I added them in to ensure that nothing was actually being sent to the back-end servers.
Do any of you have any insight as to why this would happen?
Cheers!
Further experiments make me think it is (I know this is bizarre) something to do with getting the strings from the DataGroup… It makes no sense to me at all. I have another iRule that does work:
when RULE_INIT {
     Set this option to 1 to log debug messages (to /var/log/ltm by default)
    set static::debug_managed_path_redirects 0
    set HTTP_PATH [string tolower [HTTP::path]]
    switch -glob $HTTP_PATH {
        "/projects-projets*" -
        "/governance-gouvernance*" -
        "/communities-communautes*" {
            if {$static::debug_managed_path_redirects}{
                log local0. "Match found in $HTTP_PATH"
            if {$HTTP_PATH starts_with "/projects-projets" } {
                set LONG_MANAGED_PATH "/projects-projets"
                set SHORT_MANAGED_PATH "/pj"
            } elseif {$HTTP_PATH starts_with "/governance-gouvernance" } {
                set LONG_MANAGED_PATH "/governance-gouvernance"
                set SHORT_MANAGED_PATH "/gv"
            } elseif {$HTTP_PATH starts_with "/communities-communautes" } {
                set LONG_MANAGED_PATH "/communities-communautes"
                set SHORT_MANAGED_PATH "/co"
            set PATH_LENGTH [string length $LONG_MANAGED_PATH ]
            set REDIRECT_PATH "$SHORT_MANAGED_PATH[string range [HTTP::uri] $PATH_LENGTH end]"
                log local0. "REDIRECT_FROM:$HTTP_PATH - REDIRECT_TO:$REDIRECT_PATH"
            HTTP::redirect "$CLIENT_HTTP_TYPE://[HTTP::host]$REDIRECT_PATH"
        default {
             don't do anything...
The above code redirects correctly.
I then went and created a new Data Group with the following entries:
class SharePoint-Managed_Path_Redirects_DataGroup {
And modified the code in my original question to use the new data group for matching, but use the string substitution from the working redirect to create the redirect URL:
    set MATCH_FOUND [class match [string tolower [HTTP::path]] starts_with SharePoint-Managed_Path_Redirects_DataGroup]
    if {($static::log_old_to_new_path_redir2) && ($MATCH_FOUND)}{
    if {$MATCH_FOUND} {
        set KEY [class match -name $HTTP_LPATH starts_with SharePoint-Managed_Path_Redirects_DataGroup]
        set VAL [class match -value $HTTP_LPATH starts_with SharePoint-Managed_Path_Redirects_DataGroup]
        set PATH_LENGTH [string length $KEY ]
        set REDIRECT_URL "$VAL[string range [HTTP::uri] $PATH_LENGTH end]"
            log local0.info "URI_PATH:[HTTP::path] - KEY:$KEY - VAL:$VAL - REDIRECT_URL:$REDIRECT_URL - SRC:$CLIENT_ADDR  ID:$ID"
And the redirect gets aborted using the above. So strange (to me)…
