Im not sure about F5 iRule can or not solve this solution , i need rewrite to , only rewrite “iphone.aspx” to “mobile” this key point and the token number need same .. anyone can help this ? thanks .
Yeah you can do with irule. Try below..
set id [URI::query [HTTP::uri] token]
if { [HTTP::uri] starts_with "/iphone.aspx" } {
HTTP::redirect "https://www.abc.com/mobile?token=$id"
Do you want to rewrite or redirect?
For a rewrite:
if { [HTTP::path] equals "/iphone.aspx" } {
HTTP::path "/mobile"
For a redirect
HTTP::redirect [join [list "/mobile" [HTTP::query]] "?" ]
Join command is there to add question mark only if query string is not empty
