iRule hlep
I need to redirect from http to https , also since some users have bookmark specific port for exmaple port 8050 in their browser to be redirect to https. how do I do that.
does this works?
if { ([HTTP::uri] eq “/”)}{
HTTP::redirect “”
when HTTP_REQUEST_SEND {
clientside {
if { ( ($example_host eq “example.com”) } {
HTTP::header replace Host “example.com:8050”
Thx
How about this one?
if {[HTTP::uri] equals {http://example:8050}} {HTTP::uri {https://example.com}
HTTP::redirect https://[IP::local_addr][HTTP::uri]
Thx all
KJ
I’m not 100% sure of your requirements but this is a simple irule to redirect all http requests to the vs to https and removes any non-default port. Taken from: DevCentral
  HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri]
Hope this helps,
N
Thx, our requiremnets is to redirect HTTP to HTTPS and secondly if some user has bookmark port:8050 they also need to redirect to https.
does this will work?
HTTP::redirect https://[getfield [HTTP::host] “:” 1][HTTP::uri]
or
if {[TCP::local_port] != 443}{
HTTP::redirect " [HTTP::host] “:” 1][HTTP::uri]"
also what does getfield do?
thx in advanced.
KJ,
The getfield bit is stripping out the port, if it’s a non-default one. This should cover both bases, no port specified and 8050 in any bookmarks.
N
Not sure if this will apply but I have used this when we know what the URI starts with and we want to redirect them to a different path on the same host, this uses a 301 redirect instead of the normal 302
if { [string toupper [HTTP::uri]] starts_with “/PATH1/PATH2/” }{
HTTP::respond 301 Location “https://example.com/newpath1/”
KJ
If I understand correctly you are just needing to redirect everything that isn’t 443 I would just put up two virtuals with the same IP one listening on ANY port and the other listening on 443 then just put in a http to https redirect on the ANY listener. The more specific listener will override the ANY to prevent any looping.
e.g.
[root@ve10:Active] config  b virtual wildcard list
virtual wildcard {
   destination 172.28.19.79:any
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
        log local0. "\[HTTP::host\] = [HTTP::host]"
        log local0. "\[getfield [HTTP::host] : 1\] = [getfield [HTTP::host] : 1]"
        log local0. "\[HTTP::uri\] = [HTTP::uri]"
        HTTP::redirect https://[getfield [HTTP::host] : 1][HTTP::uri]
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:443
   ip protocol 6
   profiles {
      clientssl {
         clientside
      tcp {}
 on client
 curl -I http://172.28.19.79:8050/something -H "Host: www.somedomain.com:8050"
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
 on F5
[root@ve10:Active] config  tail -f /var/log/ltm
Sep 30 20:53:10 local/tmm info tmm[4925]: Rule myrule : [HTTP::host] = www.somedomain.com:8050
Sep 30 20:53:10 local/tmm info tmm[4925]: Rule myrule : [getfield www.somedomain.com:8050 : 1] = www.somedomain.com
Sep 30 20:53:10 local/tmm info tmm[4925]: Rule myrule : [HTTP::uri] = /something
Thank you for your help.
I already have VS_80 and VS_443 and applied redirect from 80 to 443, do I need to change 80 to all port or create new VIP with all port, and can this iRule work for redirect on *_VS ?
HTTP::redirect https://[HTTP::host][HTTP::uri]
do I need to change 80 to all port or create new VIP with all portyou can change this virtual server port 80 to any port.
can this iRule work for redirect on *_VS ? i think you should use the one nathan suggested.
Thx, and this :when HTTP_REQUEST {
will be applied to all port VIP?
Thx again
will be applied to all port VIP? yes. please be noted that non-http traffic will be dropped.
Thx, for your time.
