I see quite a bit of irules that redirect http 443 to a different port, but not finding anything that can do the reverse. I have a server sending ssl requests to port 3233 I’ve created a Virtual server to open the port but haven’t been able to get all https traffic received on port 3233 redirect to port 443. Any help is appreciated.
If you have port translation configured on your virtual server (the one listening on port 3233) and the default pool configured as the pool with members listening on port 443, you should be good to go.
To determine which solution would work for you, could you please paste your current Virtual Server and Pool configurations? I’m assuming your current implementation works via 2 different Virtual Servers & 2 Different Pools.
tmsh list ltm virtual
tmsh list ltm pool
tmsh list ltm pool
