Irule help
Hi everyone,
I need a small help to write an irule which send a particular request coming to the VS to a particular pool member, details are as follows.
http://link.com:6060
if the above request comes it should always go to one of the members in the pool containing 4 members.
but if the request is http://link.com. It is distributed to all the members in the pool.
Regards
just to challenge you a bit, have you already started something? or do you expect a full solution? :slight_smile:
Hi boneyard,
I am looking for a complete one pls.
Regards,
Hello
anyone pls…
