I’m looking for a way to make maintaining/managing an existing iRule I have. I’m having a blank moment on trying to organize the HTTP host and uri path match logic. The iRule is similar to this:
Code when HTTP_REQUEST {
set pool_select_value [class lookup [string tolower [HTTP::host]] HOST_2_POOL_DG]
if {[active_members $pool_select_value] > 0 } {
log local0.notice "Available pool members in Pool: $pool_select_value"
switch [string tolower [HTTP::host]] {
"hostdev" -
"hostdev.domain.name" -
"hostdev.sub.domain.name" {
if uri is root then redirect to the subdirectory
switch [HTTP::uri] {
"/" { HTTP::redirect "/host-DEV/"
"host2sdev" -
"host2dev.domain.name" -
"host2dev.sub.domain.name" {
ir uri does not contain /name/ at the begining, insert name
switch -glob ![string tolower [HTTP::uri]] {
"/host2-services-dev/*" { HTTP::redirect "/host2-services-DEV[HTTP::uri]"
pool $pool_select_value
log local0.notice "NO Available members in Pool: $pool_select_value
set IFILE_RAW_ERROR_PAGE [ifile get "NoPoolMembers.html"]
set POOL_VAR_NAME_REPLACEMENT [list "pool_select_value" $pool_select_value]
set IFILE_FINAL_ERROR_PAGE [string map $POOL_VAR_NAME_REPLACEMENT $IFILE_RAW_ERROR_PAGE]
HTTP::respond 503 content $IFILE_FINAL_ERROR_PAGE
I guess i’m looking for a method/ideas on using data groups to organize matches and appropriate responses. HELP!!!
