I have a website called ‘bigip.com’, however, I also have a website call ‘BIG-IP Application Delivery and Security Services | F5’ and ‘BIG-IP Application Delivery and Security Services | F5’ using the same VIP. Each url needs to point to a different pools. How can I write an iRule where bigip.com point to a pool called ‘bigip’ on port 1000 and BIG-IP Application Delivery and Security Services | F5 points to a pool called ‘bigip2’ on port 2000 and BIG-IP Application Delivery and Security Services | F5 points to a pool called ‘bigip3’ ??
Thanks for any help
Here is a tutorial: iRules 101 - Selecting pools, nodes
This should work for you. Your port number is controlled in the pool itself so there is no need to specify that in any way. Also depending on the use case you may want to use “contains” or “starts_with” instead of “eq” in the second and third condition of this iRule.
if { [HTTP::uri] eq "/" } {
pool bigip
} elseif { [string tolower [HTTP::uri]] eq "/blog" } {
pool bigip2
} elseif { [string tolower [HTTP::uri]] eq "/application" } {
pool bigip3
If no pool is configured in the virtual as a default/fallback
default { pool bigip }
This is how I do what your are looking to do. I updated /blog_ to /blog* and /application_ to /application*.
Check requested uri header (set to lowercase)
switch -glob [string tolower [HTTP::uri]] {
"/blog*" {
pool bigip2
"/application*" {
pool bigip3
default {
pool bigip
Thanks Steve. I appreciate your help.
