Hi all, I need to write an iRule that will will do the following:
Detect if the Accept header is missing.
The Connection for keep-alive is set to close.
That there is a valid keep-alive value.
If all three conditions are met then I need to log and block the traffic. I bundled all three conditions into one statement because I wasn’t sure if I needed an elseif statement or if there is a conditional statement I could use to check each one and then log and drop the traffic if all three are met. Here is my attempt at doing this:
when HTTP_REQUEST { if {([HTTP::header “Accept”] eq “” and [HTTP::header “Connection”] eq “close” and [HTTP::header “keep-alive”] matches_regex {([0-9]+)})} { log local0. “Invalid attempt.” return } }
If possible, please help.
Patti, can I assume this is related to post: https://devcentral.f5.com/questions/irule-syntax-need-help-with-conditional-statementanswer82657?
I wasn’t sure where to go with that one based on the stated requirements, but it sounds like you’ve been able to define what the HULK HTTP DoS filters are doing.
In any case, here’s what that iRule might look like:
if { not ( [HTTP::header exists Accept] ) and ( [string tolower [HTTP::header Connection]] equals "close" ) and ( [scan [HTTP::header Keep-Alive] %d data] > 0 ) } {
log local0. "Invalid attempt"
reject
Might I also add that, based on what I’ve seen from the following:
http://blog.spiderlabs.com/2012/05/hulk-vs-thor-application-dos-smackdown.html
You can also detect Hulk based on the ordering of the HTTP headers:
Accept-Encoding
Host
Keep-Alive
User-Agent
Accept-Charset
Connection
Referer
Cache-Control
So then the following might actually prove a more comprehensive filter:
set header_list [list "Accept-Encoding" "Host" "Keep-Alive" "User-Agent" "Accept-Charset" "Connection" "Referer" "Cache-Control"]
set match 1
for { set i 0 } { $i < [llength $header_list] } { incr i } {
if { not ( [lindex $header_list $i] equals [lindex [HTTP::header names] $i] ) } {
set match 0
if { $match == 1 } {
log local0. "match"
Hi Kevin, it is related to the previous post. I did some additional research to figure out what the filters were looking to do. Sorry for the confusion of the first post!
Can I ask you to explain what the second iRule is doing? Would it be beneficial to create two separate iRules for this? One to look for the original filter and the second one to look for the ordering of HTTP headers?
Thank you very much for your help!!! I GREATLY appreciate it!!!
These are either/or iRule options. The first iRule above simply mimics the filter you’re trying to replace. The second iRule steps through the defined list of headers (IN ORDER) to see if the incoming request matches this order. I’m basing the second iRule on the findings in the Spiderlabs URL.
Hi Kevin, thanks again for your help!!!
