I was wondering if someone could give me a hand with an iRule. I am trying to redirect all test.website.com traffic to test.website2.com EXCEPT traffic going to test.website.com/Three (I don’t want traffic going to test.website2.com/Three). Can anyone tell me what I am doing wrong? I have attached my iRule as a reference.
I think one issue with your iRule is that you’d redirect any request with a host header value of test.website.com to test.website2.com[HTTP::uri] before checking the URI.
How about something like this? If you want an exact match only on the URI, remove the -glob flag from the switch command and the * at the end of /Three/.
log local0. "[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::host][HTTP::uri]"
Check requested host header value
if {[string tolower [HTTP::host]] eq "test.website.com"} {
log local0. "[IP::client_addr]:[TCP::client_port]: Matched Host check. Checking URI now."
Check the requested URI
switch -glob [HTTP::uri] {
"/Three*" {
Requested URI started with /Three
log local0. "[IP::client_addr]:[TCP::client_port]: Matched URI check for /Three. Allowing request to go to pool"
default {
HTTP::respond 301 Location "http://test.website2.com[HTTP::uri]"
log local0. "[IP::client_addr]:[TCP::client_port]: No URI match. Redirecting to http://test.website2.com[HTTP::uri]"
Here are a few example of using glob style patterns:
switch -glob $some_string {
"1" -
"2" -
"3" {
Matched 1, 2 or 3
"[4-6]" {
Matched 4, 5 or 6
"[d-f]" {
Matched d, e or f
"z*" {
Matched anything starting with z
"*z" {
Matched anything ending with z
default {
No match. Default case
"/Three*" -
"/Four*" {
Requested URI started with /Three or /Four
log local0. "[IP::client_addr]:[TCP::client_port]: Matched URI check for /Three or /Four. Allowing request to go to pool"
default {
