iRule help for two redirects based off uri with variable
I’m trying to create an iRule that does the following redirects:
http://xxx.com/ → https://yyy.com/find-a-provider/
XXX.com | XXX Sex Videos & Porn Movies Tube → https://yyy.com/find-a-provider/physician/UserValue
The first redirect based on a uri of “/” is pretty straight-forward, but the second redirect that needs to repopulate the UserValue and tying it all together in one rule is where I’m struggling. Any suggestions greatly appreciated.
Can be done but consider second redirection option then 1st. Let Devcentral team knows if any questions.
Hi RobS,
Can you try this iRule?
	switch -glob [HTTP::uri] {
			HTTP::redirect "https://yyy.com/find-a-provider/"
		"/Home/Physician?profileId*" {
			set UserValue [URI::query [HTTP::uri] profileId]
			# log local0. "profileId = $UserValue"
			HTTP::redirect "https://yyy.com/find-a-provider/physician/$UserValue"
Thank-you, this works great! I didn’t realize I could just pull the value of profileId and thought I was going to have to parse the uri.
