Irule header APM
Hello,
The fact that the EXAMPLE * header are eliminated by the F5 blocks any possibility of traceability of our messages within our information system for some VHOST.
I already set up irule to add some header but in this case I want the header is not reset.
Do you know an irule for that ?
Thanks in advance.
Regards,
Your question is not clear enough for me. Are you talking about the HTTP header? Can you provide an example of what you want to do ?
Hi Nicolas,
I would like the virtualhost https://test.com headers EXEMPLE* to be preserved :
EXEMPLE_TX_ID
EXEMPLE_SPAN_ID
EXEMPLE_PARENT_SPAN_ID
Regards,
up
To make it more clear (your question) you want the BIG-IP not to make any changes to the EXAMPLE_TX_ID and EXAMPLE_SPAN_ID header?
Cheers,
Kees
Hi Kees,
That’s right
Regards,
Hi Jean,
My apologize for this late answer. Do you have an ASM profile attached to your vHost/VS? Because the default behavior of HTTP profile in LTM is to preserve client headers normally, your issue should not happen.
You can try this iRule otherwise (not tested):
    set HEADER1 [HTTP::header "EXAMPLE_TX_ID"]
    set HEADER2 [HTTP::header "EXAMPLE_SPAN_ID"]
when HTTP_REQUEST_SEND {
    if [string length $HEADER1] {
         HTTP::header replace "EXAMPLE_TX_ID" $HEADER1
    if [string length $HEADER2] {
            HTTP::header replace "EXAMPLE_SPAN_ID" $HEADER2
To get the above irule to work with APM you need to add:
when CLIENT_ACCEPTED {
    ACCESS::restrict_irule_events disable
The APM has it’s own HTTP server and bypasses the LTM HTTP server.
Cheers,
Kees
Thank you Nicolas & Kees for your return.
the http profil i’m use is http-xff. I adapted your irule to force the insertion of the header and it works.
when I try to apply the irule to the vhost with your code in addition i can’t apply it : 01070394:3: ACCESS::restrict_irule_events in rule (/HorsProd/header_APM_test_horsprod) requires an associated ACCESS profile on the virtual server (/HorsProd/Example_VHOST_443)
Regards,
Hi Jean,
So your not using APM (as stated in your subject of this question)
But good to see you got it working in the end.
Cheers,
Kees
